head unit install
  • Thread starter Unregistered
  • Start date
  • Replies 1
  • Views 1K
  • 1
I just looked at the dash of the 2002, and it looks like your climate controls and the stereo probably share a bracket, but the factory stereo is din size. Your new radio should go in with no probs, just mount it in the bracket with the screws provided with the stereo (the short 1/4 inch screws). If you rl is older I believe the radio is a din and a half, in which case you need to get a hold of a honda pocket (junkyard or maybe a shop with a bunch laying around) and the bracket to attatch the radio and pocket together. You may have to cut the trim ring off the new radio
Pull the head unit out, and at the harness use a test light to check 12v, ground, and Accessory. If all three are good, you have probably...
Youll need a Honda Civic reverse radio wiring harness and 20 toyota radio wiring harness ...match colors of wires and shes ready to go...
Installing a Jensen CAR710W head unit in my sons 2013 Volkswagen Golf. No steering wheel controls. I purchased the XSVI-9003-NAV wiring harness...
262
614
Guest
gregj9
    May 24, 2024
