Any suggestions?
Nexasnight
I've got a 1400 watt Pyramid Gold series, 4-channel amp and two older cone style Kicker Solo Barics, any suggestions on the best way to do the wiring and does anyone know how to strap an amp? Any and all suggestions would be greatly appiciated. And if it helps any, I'm putting the system in a '95 Two door, Pontiac Grand Am. E-Mail me at NexasNight@Hotmail.com.
What I recomend is find out if the amp is two ohm stable in bridge mode and if so then I would bridge the rear channels and run your subs in parallel and your mids/highs off the front two channels. If you don't need more power for your mids/highs then do what he said and bridge it to two channels and run a sub to each one. I also think you should try and get a better amp.
Nexasnight
Nexasnight
Oklahoma
Robert1999
    Jul 7, 2025
Robert1999
    Jul 7, 2025
