Have a problem with setup
My box is a ported box, it was made for the type R. And I have the filter set at 30hz.
like others have stated on here set the bass boost on the amp to 0. this can cause an amp to clip quickly. I don't agree with the others on here either that sub should be able to handle 1200 watts no problem.
What exactly does that do? I know it sounds different, I just don't know what it is actually changing.
Its basically boosting a certain frequency. Main just causing major distortion in your current setup. Have it completely off and set the gains with a multi-meter, get any 15-20$ multi-meter from walmart, Frys, Sears etc... brand dont matter just get one.
Sub level all the way up, on the head unit, Equalization flat, low pass and high pass filters both at 80hz, bass boost off, loudness off.
on the amp, bass EQ all the way down completely.
We can fix that, //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I have a 20kw amp here i can tone down to see if it can handle 1000w.
I know it doesn't.. physically impossible based on engineering.
If you have easy access to the RCA wires at radio side, disconnect them. If no easy access, use a spare set of RCA wires to plug into the amp...
Love the site, arguments over non-issues, not so much. ;)
13
88
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
841
ragtopman
ragtopman
United States
shizzzon
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
