Have a problem with setup
ragtopman
Hi all,
I use to have the Alpine MRV-M500 and did have it put in professionally, nothing was wrong there. I just recently changed my amp out and upgraded to the alpine MRX-M110.
I have the amp hooked up to 1 Alpine SWR-10D4 type R running at 2 ohm. Now as far as my knowledge goes, that sub should be able to handle that amp and sound great. The RMS of the sub (for those that don't know) is 1000 watts, and the MRX-M110 came at 1207 watts.
The problem is the voice coils are heating up thus creating a burning electrical smell when the sub hits hard for >5 min. The gain is below half but yet when I turn the volume to 3/4 and have a hard hitting song, you can smell it. I don't know what to do but wire the sub at 4ohm to have 600ish watts run to it.
Any help on this would be very much appreciated!
That sub can only be wired to 2 or 8 ohms. How did you determine how you set gain? Sounds like you have a miss match. Trying to avoid the c word. Simple solution turn the gain down on the amp until the voice coils quit heating up. Good luck with it.
The sub is wired at 2 ohm, I set the gain off of ear and it is about half way. There is also a bass EQ on the amp, and that is set at half way also. Above 3/4 volume you can start to hear distortion in the music. But when it is 3/4 or lower (but still loud) and I have hard bass going, just starts to smell. If I do turn the gain down, its almost no bass at all without cranking the volume all the way up.
Is the sub new? if it is its probably defective if not it may be time for a new sub. A type r will take the power your feeding it easily.
Nope, had the sub since February. Everything was fine up till now, and that is exactly what I was thinking about it taking the power easily.
I'm going to assume several things here so here i go-
Alpine says 1000wrms, 3000w peak
Voice Coil Diam. 2.6"
Those specs do NOT mix together..
But, to give Alpine benefit of the doubt, i looked at the driver..
The entire underside of it is enclosed minus a useless pole vent that doesn't really help with cooling.
So, the power ratings must be from Apparent Power instead of actual power..
So, an amplifier rated no more than 1,000wrms, clip free would work but anything over that wouldn't.
That means the actual RMS of the driver is probably around 400wrms Reactive.
I would say some clipping is at play here but also if not, the amplifier could be too much for the sub based on hardware limitations.
The starting ask on diyca.com is $2,500, so no telling what they want in the end, maybe $500k lol. Funny that caraudio.com is no longer valid for...
19
76
Sweet!! Im happy to hear that it was not a major issue.!! Very nice man. Thanks for letting us know what the culprit was!!
19
909
https://www.caraudio.com/threads/all-bnib-focal-fdp-4-600-ds18-exl-p2500-1-sundown-audio-sfb-1000-4d-350x4-4ohms.614462/ :)
18
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
659
ragtopman
ragtopman
United States
shizzzon
    May 18, 2024
    May 18, 2024
