grounding wiring
so, it is best to ground the amp to the negative terminal on the battery itself? would that not put too much stress on the battery? i cant find a proper grounding point in the trunk of my thunderbird so I dont know what else to do. ive also heard that the ground wire can only be so big...is this true? Thanks
well, there's some truth to that...ever seen 4/0 gauge cable? hehe...
4/0.. I have 50 feet of that.. stuff is a ***** to work with!
4/0 is quite a sight to see..
but 750, 1000, or 2000MCM will literally make your jaw drop.
2 inches of wire. Not length.. DIAMETER.
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I don't think I've actually ever seen it...the local ag store sells tractor battery cable up to 3/0 in gauge, and that stuff is beastly...
makes my 2awg look wimpy //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
KCMIL is a quantity of measure units; KCMIL is 1000 CMILS. All wire sizes larger than 4 ought AWG are given as KCMIL sizes. KCMIL wire size is the equivalent cross sectional area in thousands of circular mils. A circular MIL (CMIL) is the area of a circle with a diameter of one thousandth (0.001) of an inch, often termed CMA. Be aware that the wire sizes in the KCMIL system increase as the numbers get larger, which is exactly opposite from the AWG system.
from http://www.csgnetwork.com/glossaryk.html#KCMIL
so big and thick the rolls have to be unloaded with a crane of sorts....they call it flexable...if you can cut off a foot of it and use it to smash out windows and kill someone, i don't call it flexable....or if you need a 2 foot piece of ridgit conduit to make it bend where you want it to, cause it's to thick to manipulate.....
clarity413
clarity413
Bakersfield, CA
taylor
Jared Schwersky
    Jul 19, 2026
Jared Schwersky
    Jul 19, 2026
