Going from 2ohm to .5
Only one way to find out..
Just hope you have the electrical to support that .5ohm load.
What would the electrical load difference be? Sorry I see the title of my post says 2ohm but it is supposed to be 1 //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
What ohm are you subs? If D4s you have a choice of 2ohms or 4ohms. D2s you can do 2ohms or .5 ohm.
Mo powa needs mo electrical. Low voltage at under rated ohm load is a bad idea.
The diff will pull juice like nothin , make sure your backin it correctly right now im in a 96 tahoe , stock alt and a yellow top @ .5 on an hdc4 18 and atomic at1600.1 and it drops pretty good still holds solid but my amp can play down to 10v so im good not a good idea but i know what im doin so im safe but make sure you have a stout electrical system to back it to save your behind , at .5 things heat up and break pretty fast if you dont know what your doin and coils will burn , oan distributing between more than one coil is better on the coils but like i said heat will be an issue
you definately need some type of voltage read out on your dash before you make this switch
its possible the amp will pull voltage down to single digit teratory and cook / possibly cook some car electronics as well
but
if you watching voltage drop at the dash when playing you can turn down volume a bit when it gets to the border line of un safe
you definately need some type of voltage read out on your dash before you make this switchits possible the amp will pull voltage down to single digit teratory and cook / possibly cook some car electronics as well
but
He is correct ^^^^^
---------- Post added at 04:25 PM ---------- Previous post was at 04:24 PM ----------
Make sure the volt meter is hooked up at the amp to know exactly where its at
dhall615
dhall615
ATL
Nutdawg651
BP1Fanatic
BP1Fanatic
