Gaining voltage
  • 6
Voltage is dependent on the regulator in your alternator. If you are asking about ways to prevent voltage DROP then no there really isn't. But if you want to know how to physically gain voltage, that has to do with your alternator (or if you have an aftermarket alt, the external regulator)
Not that I have used one, but isnt that what those voltage modules from companies like Missing Link Audio do? I thought the modules bypassed the car's CPU so you could run the alt a higher voltage. Like you guys said, no matter what you do some cars computers will never raise the voltage past a certain point.
Yeah, put the probes on the power wire and ground wire of the amplifier. Multimeter on DC. Do not put it on the wires that go to your speakers. M
514
It's still a very small company that is growing. And growing has its challenges. He is very active on Facebook and does plenty of real test...
The AudioControl LC7i has a maximum output voltage of up to 8.5volts. It can output up to 8.5 volts which is more than a typical aftermarket head...
Below20hzonly
Below20hzonly
East Grand Forks, MN
Jroo
    May 24, 2024
