gain setting on multi ch. amps
the problem i have is the equation to finding the output voltage at which to set an amp to, doest account for channels. its the sqrt (rmsxohms). and my amp is 2ch. only has one gain. when bridged it does 200x1 at 4Ω. so that gives me an output voltage to set the gain to around 28v's. so do i hook the meter up bridged then?
obligatory note that max unclipped gain in no way is acoustically optimal, and should not be used if the levels are not readjusted elsewhere as needed.
well it does 200 rms when bridged, if that, cause im never always at 14.5 volts. it does 75 rms x 2 but how would i calculate that into an output voltage at which to set my amp? i mean ive done it by ear, and both amps where set to a good balance, just seeing how close i came to being exact.
so who likes to make there own black and tans? im off to the store, maybe some Sierra navada pale ale mixed with some porter sounds delish but id like to set my gains right....
"correct" implies a goal. any gain setting is correct if it meets the criteria you set.
eg, one person might set the gain such that the amp acheives maximum undistorted output at 20/30 on the HU.
person two might set it such that the amp acheives the rated power of the attached speaker at 20/30 on the HU.
person three might set it such that the speaker acheives a desired "normal listening" SPL at 20/30
each person had a reason for the gain setting. really, all you can do with the DMM is check to see if you might be overpowering the speaker, or maybe clipping.
cshaw
free the robots
cshaw
south florida
thch
Mike Mccabe
