gain set
//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The amp has no bearing on what the input gain should be set at, its your HU that determines that. Someone will throw a link up here soon enough about how to do it, i'm too lazy to find it.
so for the comps amp
110 by 2 (12.5 volts) at 4 ohms per channel
but my car is about 13.5 volts when volume pumping
so my amp would be putting out around 125 watts a channel at 4 ohms
125 by 4 is 500 and the square root is 22.3
right/ wrong?
right/ wrong?
To figure out the output voltage you need to do this:
Voltage = square root of (Power * Resistance)
So, 500x4 = 2000 - square root of 2000 = 44.72
44.72 is your output voltage
his amp is a 2-channel. it would be 125 time 4 which is 500 and then the square root of that number. not sure where you are getting your numbers.
DFW40
DFW40
Keller, TX DFW area
DFW40
