fuse holder smelling REAL bad
Ya My fuse holder is smelling real bad. It also gets VERY hot. Could this be because I have a smaller fuse then reccomended? Only fuse i had to run to my amp was a 150 amp.
if it was pulling too much, it would blow (or partially blow...lol)
it maybe pulling right at 150a.. idk. check the connections. is any metal touching the car (aka short circuit)?
YA i double checked everything. Thats what i dont understand its smelling and getting real hot then why isnt it blowing? its only 150 amps off 1/0 gauge wiring. I just think the zx2500 is trying to pull to much current that it cant all get through the 150 amp fuse
Bad connection, too small power wire, bad ground, could possibly be the fuse but would most likely blow due to over current.
Maybe you farted?
The fuse would blow if that were the case. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
i had my 1501d on a 150a for a long *** time. never did that.
have you tried giving it a bath?
did you piitb?
What they said.
I just took this pic looks like the fuse was corroding or something. I just put a diffrent 150 amp fuse so i will see what that does.
daaaaaaaaaaaaamn that is bad... glad you swapped out fuses. if you need any 150a's let me know i have a bunch for ya //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
mazzasec
Banned
mazzasec
ATL
jco1385
