Fuse/Deck help
  • 4
more_spl
only have 1, but it's 12"
2,487
Winnipeg
ok, unsureness strikes.
heres the scenario:::::
installed deck in a 1985 car (so it's older..)
now im more than certain, that this fuse ONLY blows when the deck is on/playing.
these are the functions of the fuse that is blowing::
courtesty lamps, key warning buzzer, clock, illuminated entry, CB memory, etc..
The fuse is a 15A that keeps blowing. soooo, im wondering, is it safe to step up to a 20A, or 25A fuse and see if it stops blowing? i need my analog clock and interior lights.
::pLEASE ANSWER THIS QUESTION TOO::
Reason im asking is cuz while we were doing the install, a relay box hit a piece of metal inside the car and sparked, so we were unsure if it was a short or not... But on the way home, i didnt power up the head unit, and the lights and clock fuse didnt blow.. So is it safe to assume that the head unit is pulling too much amperage for that 15A fuse?
I had somthing similar happen in my 86 cutlass when I mistakenly connected the decks ground wire to the dimmer wire from the car, reground your deck elswhere and see if that stops it.
the deck is grounded to a piece of perfect ground underneath the dash, how will finding a new place make a difference??
The thing is, the fuse isnt blowing when i am driving the car and the deck has not been powered on... But when the deck goes on, it blows a few seconds afterwards?
Did you use a wiring harness to connect to the factory harness or did you cut off the factory plug and hard wire it, it really sounds like you connected a wire wrong.
Nomatter what your gonna havta pull the deck out and check your wires.
BTW- Is the fuse on the deck a 10amp, if it is then there is no way it could pull enough current to blow the 15amp fuse and not blow the 10.
good question about the deck amp. 3 years ago when i originally had it installed by a shop, they cut off the fuse line for it.. so i dont know. //content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
I made a lot of money repairing fuse boxes that were destroyed from people taping into them. Pay once by doing it right. Do it wrong, the second...
14
363
It would be cheaper, it might be easier to find a place to mount it, and you would have a ton of options if you just do two, 3 slot fuse holders...
4
635
My bad, yes, I read them each as having two 4ohm coils. The JBL diagram left a bit to be desired, IMO. ;) And a double yes, thought U was talking...
9
I plan on getting the fuse to run as a front sub/midbass in my kick panels...I've heard they sound good but you definitely wont get mirror shaking...
more_spl
more_spl
Winnipeg
more_spl
winkychevelle
    May 24, 2024
