FS/T: Fosgate Power 250m Minty!
  • 1
OldSchoolRF
1. Product:
Rockford Fosgate Power 250m with End Caps
Comes with Original Box & Manual
2. Specs:
Put Rockford Fosgate's elite technology and obsessive attention to detail to work in your vehicle! Their Power 250M full-range mono amplifier will have you basking in 125 watts RMS of pure power. Better yet, string together two 4-ohm subwoofers (for 250 watts RMS at 2 ohms) and bring on the boom!
A variable low-pass crossover (50-250 Hz at 24 dB per octave) improves performance by blocking unwanted frequencies from your speakers. The cast aluminum heatsink dissipates heat with 30% more cooling efficiency than standard heatsink designs. Heavy-duty power, ground, and speaker terminal connectors accept up to 8-gauge wire. If space is an issue in your vehicle, you can remove the amp's endcaps for a wider range of installation options.
Details:
125 watts RMS x 1 at 4 ohms
250 watts RMS x 1 at 2 ohms
requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
selectable 50-250 Hz variable low-pass crossover, 24 dB per octave
TRANS•ana circuit designs keep voltages low and signal paths simple in the pre-amp section, for minimum distortion and maximum musicality
MEHSA provides more efficient transfer of heat from MOSFET output devices to the heatsink for cooler operation
TOPAZ — noise-killing differential inputs that eliminate 80% of ground loop noise
NOMAD — advanced protection circuitry for "intelligent" shutdown protection
preamp-level inputs
preamp outputs (for passing signal to another amplifier)
aluminum heatsink for more efficient cooling
dimensions: 11-7/16"W (7-13/16" without endcaps) x 2-7/16"H x 9-7/8"D
3. Description/Condition:
This amp is in very near mint condition just a little dusty. I am the original owner and it was used for about a year to power a 12" Punch HX2 in my wifes car. This amp is rated at 250rms @ 2 ohms but I clearly remember the birth sheet stating 376rms @ 2 ohms on 13.8 volts. This amp also comes with the original end caps, box, and manual.
This amp would be perfect to run your midbass or even a small sub. These amps are tanks and even though its almost 10 years old, it still performs like it was new. They don't make them like this any more. Made in the USA!
4. Price: :
$125 plus actual shipping OBO
5. Trades:
These are the only items I am looking for on trade. I can add cash where necessary..
FNQ Component Tweeters & Xovers
Symmetry EPX2
AudioControl 6XS
AudioControl Epic 160
Black Top Team RF Motors
Power 1500bd & 1501bd
Power 800.4
Power 750X
Triple X RCA Cables
1/0 Gauge Fosgate Wire
6. Pictures:
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
OldSchoolRF
OldSchoolRF
Kentuckiana
OldSchoolRF
HandsomeSteve
HandsomeSteve
