2 Sundown Saz 1k's
Used for maybe an hour per amp, these are overbuilt like all of the SAZ lines, should do 1300-1400 per amp easy, Have bass knobs for each, only scratches are on the mounting holes..Other then that they have been very well taken care of
SPECIFICATIONS:
Digital Class-D Linkable Mono Block Amplifier
Double Sided Through Hole Epoxy PCB
1 Ohm Stability
Efficiency : 86% @ 4 ohm, at 100Hz
24dB/Oct Variable Crossover
Multi-Way Protection Circuitry (Thermal/Over Current/Speaker Short/Speaker DC Protection)
RCA Line Input and Master Output
24dB Octave Crossover Slope
Variable Subsonic Filter
Variable Bass Boost
Variable Low Pass Filter
Variable Phase Shift
Four(4) Gauge Power Supply Connectors
Tested Voltage & THD : 14.4V & Less than 1% THD
Operating Voltage : DC 10V~16V
Wired Remote Controller
MSRP $499 USD
Rated power output
----RMS power, 2 ohm linkable/dual mono
1800W x 1CH ----RMS power, 1 ohm mono
1000W x 1CH ----RMS power, 2 ohm mono
600W x 1CH ----RMS power, 4 ohm mono
300W x 1CH Signal to Noise Ratio >90dB Low pass frequency crossover 35Hz~300Hz Subsonic filter 10Hz~60Hz Bass boost @ 45Hz 0~18dB Phase shift control 0~180 degree Frequency response 10Hz~350Hz (+/- 1dB) T.H.D @ 4 ohm
$225shipped each $425shipped for both, NO TRADES!!!
If shipping outside the lower 48 hmu
2 Sundown Saz 1k's
SPECIFICATIONS:
1 Ohm Stability
Variable Bass Boost
MSRP $499 USD
Rated power output
