FS: Dynaudio MD130 Tweeters - Great SQ Tweets!!!
Drummer65
Pair of Dynaudio MD 130 Tweeters
Tweets are in great condition. 9/10 Physical 9/10 Mechanical only because they are used
The MD130 is a soft dome tweeter based on Esotec D-260, but redesigned for usage in a car and similar environment.
The optimized dome geometry and the low moving mass ensure the best possible high frequency reproduction reaching beyond 30 kHz.
The low resonance frequency and the high power handling make the MD130 the ideal choice for both two and three-way systems where the highest quality is desired. Frequency response: 2,000 Hz - 22kHz; 90 dB sens. 20 - 200 watts continuous, clean power.
WoofersEtc.com - MD130 - Dynaudio 30mm Soft Dome Tweeter
http://www.gattiweb.com/images/dynaudio/MD130.pdf
$220 Shipped FIRM!!!
They go for $219 each
USPS Priority
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Drummer65
Drummer65
Newport Beach, CA
Drummer65
    May 31, 2024
    May 24, 2024
