fourth order for apxx18?
im looking at the specs on the site i thought the apxx had a 4 inch coil? the site says 3.
yes mine does... so those arent the exact ts parameters but it is the closest thing as they dont list them on their list for the 4"vc...
so, in other words, bad for a 4th order... ***** really want one...
Maybe look into a horn, I know woofers with a qts below 20 work well in horns but that is for a flat response. Also its hard to get low bass out of something with below a qts of .2 so I would look into woofers with a low fs, that are designed to get low, that is if you wanting to build a ground pounder.
those arent even the corect ts parameters, and atomic built mine for daily and spl so I hope it will fair well in a fourth... wish I could find the ts specs on it....
Why do you feel you need bandpass alignment?
What do you think that will do for you?
You do realize that trying to put a sub with unknown parameters in a complex box is a recipe for failure?
yes I do.... but I was a noob and still am when I designed my first box and I have still not come even close to being good at designing....
Ported alignment is much more forgiving and most of the subs with stiff suspension and huge motor do well enough in DD spec box.
sorry but what does DD mean?? digital designs?? my box right now is 5.7 cu ft tuned to 40hz with 4 4 inch aeros... what do you think?? decent for that sub? even though no ts parameters are given...
With 1/4 wave and tuning low, your vehicle is a resonator itself, like if you think about from your rear hatch or back of the box traveling front...
432
There its designprogram to use fore bass boxses , if you now all parametre of the subwoofer , the made the best solutuon fore you
49
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
850
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
RangerDangerV2
RangerDangerV2
st cloud MN
Moble Enclosurs
    May 23, 2024
    May 22, 2024
