fosgate 1500-2000 rms or aq 2200.
yea thats pretty low you might lean towards 1500 watts i know you can get an amp here for that ,for my bnib dc 2.0 you'd need a bit more ,but i might be able to deal a bit on it ,but not that much.
OP, you can easily get a aq2200 for 350 shipped from someone. check out the db drive a7 2k in the fs section for 325. over 2k at 12v.
youll find your amp around here for your budget easily.
OP, you can easily get a aq2200 for 350 shipped from someone. check out the db drive a7 2k in the fs section for 325. over 2k at 12v.youll find your amp around here for your budget easily.
^^^this. Sonic is having a liquidation sale also. They had some DB Drive 2000.1's for 200 bucks with free shipping.
10
I would pull it and bench test it with a 12v battery. Ive had Bulbs burn out in the past and the amplifier works excellent. They will burn out at...
roger that, just got one from sonic electronix for $189. thanks for the help
18
Maybe ask RF tech support. I wasn’t able to find that either. Sonic electronics and Crutchfield just use the same description as the rf site. True...
rebelfromva
rebelfromva
VA
mylows10
    May 31, 2024
    May 24, 2024
