Ford keyless entry
Yeah, most aftermarket keyless entry/ alarm/ remote starter units have a factory arm and dis arm output so that when you go to unlock the doors or remote start the car it will not set off the factory alarm.
The aftermarket add on should have a disarm input on it, so if you found the wire that sent out a pulse when you correctly input the Key Code on the door, then it will disarm the aftermarket alarm.
And if you diode isolate that with the lock/unlock you will be able to use both the factory transmitter and the door keypad.
dei doesnt have an disarm input. i wish they did i have the same issue on my tbird. but he can use the key pad get in and hit the valet button and start the car to disarm the alarm
I'm thinking of the factory module (Viper 3900 Series) which should have a disarm input....
965
Ahhh, I had it in my head that it was 1 ohm stable for some reason.
41
One fuse (the 300) goes close to the battery to protect the power wire...then close to the amp you'll add another fuse (whatever size the...
29
4K
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
There is one more thing; you said you will be using the OEM amplifier for the front stage. If that is the case, then you may need an vehicle...
174
maxxguy1
After life Customs
maxxguy1
Cedartown GA
maxxguy1
