For the love of needing louder music, please help me!!
  • 5
So now does anyone know the wiring colors, what they go to behind factory radio in 2016 kia optima lx no nav, with cruise and steering wheel controls. Looking for remote or accessory wire for amp to come on when car is on or started. Thank you
Does your cigarette lighter work without the key? If no, then you can tap onto that fuse with a fuse extender. If it works without the key, then you could tap into the cluster panel fuse instead. It is easier to tap into fuses than to splice into wires behind the radio.
I'd also recommend that at the very least, you deaden the doors with some sort of mass layer like this Siless Max 120 mil (3mm) 30 sqft Car Sound...
754
They should work. I have 6.5s in my lower door to replace the 8" subs that came with my mustang. They are fantastic, and outperform the 6 x 8s...
You got plenty of space 30"h x 40.5"w x 65"d even triple baffled, double walled with bracing. What vehicle is this going in may I ask?
Yes, I have a difference, but my difference is HUGE. The difference can be so big, as if I had a sound system in about 150-200 dolars (with wires...
41
9K
im not looking to seal off im trying to stay out of wall classes and plan on staying in trunk classes
15
Mzsunshine41075
Mzsunshine41075
Ohio
mhyde71
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
