fitting 4 15s in a ranger?
got it...
Gross volume (with no front added to the design, but using internal dims up to the front lip) is 20.12 ft^3
that was fast! where should I send monies to? and with a rough estimate of displacements do you think that I can fit 4 15s??
---------- Post added at 11:45 AM ---------- Previous post was at 11:44 AM ----------
oh and there will be a double baffle so the front dim needs to be shortened by 1.5"....
did you use torres?? because thats exactly what I got... only I didnt subtract the hump in the back and the angled sides on the top.... and does this include wood displacement?
I used basic match based off your dims in the sketch up design. That is after all wood displacements though. That is exact gross volume per your design after all wood. Bracing, port, and subs are not accounted for in that volume.
you could fit it...teammate had 4 15" mayhems in his s10, a lot less room then what you have. His box was like 10cuft after displacements lolStill did good numbers tho
Just makes it peaky normally and a loss on low end. It also depends on port area and such...
Not sure why he only had 10ft3 though I had that below the window line.
RangerDangerV2
RangerDangerV2
st cloud MN
galacticmonkey
