final setup yes? no? mayb?...any suggestions?
Sundown sae 1200 is 175$ On ebay and the AQ is 250$ I see new
can u give me a link to the sundown
dvc= dual voice coil (just means it has two pairs of positive and negative hookups on your sub, it gives you more options for hooking up your subs to the amp. )
the 2 just means dual 2 ohm voice coils pretty much all subs will have 2 or 4
2 will wire down to 2 ohm load, perfect for your kicker
4 will wire down to 1 ohm
rms just means how much the amp will put out continuosly or how much the sub can handle
its the only # you pay attn to
and cheap brands will even exaggerate that
He is going to need to know how to do big 3, show him the sticky link. When I ran my BL I had a kinetik 800Hc front a 2400Hc in the back. I would reconmend Picking up a 800Hc you can find them on ebay for 100$...I don't think a stock battery Can handle 1500rms. What do you think??? that sundown only needs 12.4 voltage So he might be fine with the car running.
pineapple1
pineapple1
Florida
chase007
