FierceTimbo's SQ Build Log
So i have not been able to get much done for the last little bit, still waiting on an amplifier to make its way here and a simbilink cable, but i hope to have this done by next weekend or so, im dying without music.
Anyways today i put in my viper 5901 and ran my power and speaker wires.
Power wires in and on the battery terminals, i probably should get a new battery maybe later.
Power wire coming through fire wall, secured every 6 inches or so and speaker wire harness ran to kickpanel
My car is very dirty.
And here is my alarm i did, there is nothing really to take a picture of but thats the way an alarm should be installed. You can see my immobilizer bypass however.
im coming over tomorrow to drop the cables off. let me know whats a good time for you.
Also move that ANL fuse holder asap, i had mine on there and I had a meltdown on the block from vibrating too much.
really i check and it was not hot, ill have to go look into it.
You working on it this weekend? I could stop so i can
help and learn. I picked up 24ft of damp pro //content.invisioncic.com/y282845/emoticons/woot.gif.aaa6090e619a97b6090d16dd863c5a69.gif
Si, if you plan on doing any competing they won't like that fuse holder location at all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I most likely will never compete, but i will try to move it, not sure where im going to mount it there isnt alot of room but i didnt spend much time trying anything i was more concentrating on the alarm.
But anyways no progress really, i finally got my other amp in and got my cables from meglomanaic.
Finally
And the cables meglo made me, he said he didnt like the quality of them but im really happy, and i think they look really good.
So i have not been able to get much done for the last little bit, still waiting on an amplifier to make its way here and a simbilink cable, but i hope to have this done by next weekend or so, im dying without music. Anyways today i put in my viper 5901 and ran my power and speaker wires.
Try mounting it on the firewall or battery plastic holder like mine
You can see where my other ANL is mount near the top, right above where the intake connects to engine.
Ok so i got most of it done today, took a couple hours but im pretty satisfied.
Also i know there are some duplicate pictures because i used a real camera today, not my cell phone.
My sexy amp again, my dog luigi guarding them well.
All my wiring ran and secured, and i did move the fuse holder to the firewall, almost didnt make it because this tsumani wire is not too flexible.
The bottom of my false floor cut and mounted ready for some amps
Amps mounted and everything secured, the sub wire is temporary as i have not completely finished the baffle.
IB baffle in with the sub mounted.
More pics later tonight after im done, gotta cut my dash to fit the Z3 and RCA's and everything.
And heres my fuse holder, its not screwed its glued to the firewall with super adhesive, i will probably screw it later it just was not a priority with my limited time.
Fiercetimbo17
Fiercetimbo17
dallas
Fiercetimbo17
