EricN CX-7 Build Log
yeah i know right ls2 i've never heard of such a thing either man. maybe he will tell us.//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
8 gauge cuz I don't know what I'm doing //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Please help me on my power layout if I have it wrong.
I currently have one 1/0 gauge going from battery to fused distro in the rear of vehicle. From that distro I will have two 4 gauge and one 8 gauge going to the three amps. I now need to get power from this distro to the HU and H100 processor. Please tell me how to do that.
Ok, I'm going to use the wiring harness power for the HU. I'm going to put the processor in the rear of the vehicle and use some power from the distro.
No 8 gauge run! //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif:)
Today's Update:
Was out of RAAMmat, but UPS was delivering a roll. Problem is they don't get here until late afternoon and I took the day off.
So I decided to go ahead and remove all the door trims in prep for the RAAMmat since I was hoping to deaden all 4 doors today. After removing the trim I decided to go ahead and run the speaker wire to the front doors.
Ended up finding a nice place in the connectors that I could snake some 14 gauge wire through
Here is the connector removed:
Drilled using my Dremel and a regular drill bit. Tried act like I was a dentist and took it slow and steady so I didn't break through the other sides:
Put the connector back together and fed the speaker wire through:
Looks stock:
All done up front:
Later in the day my roll of RAAMmat came!
Went straight to it starting on the front doors.
Ended up w/ two layers on the outer door and one layer on the inner door:
Followed it up w/ a layer of ensolite on the outer door:
Then put one layer on parts of the inner membrane and around the speaker hole:
Unfortunately that took up the whole **** roll, so now I'm $200 in on sound deadner and only have two doors and a front cabin to show! still have the entire rear cargo area and two back doors. Guess I'll order two more and some more ensolite as well...
Today's update, received my 0-gauge cable so I wired up the engine. Added an 0-gauge ground and ran the power cable to the rear of the vehicle with an in-line fuse in the engine capartment.
Any fuse size recommendation? If I'm fusing the wire than I assume 250 would be ok for 0-gauge.
Pic of factory ground location:
Took it down to bare metal:
Made up my cabling with TechFlex and heatshrink:
Found the wiring hole in firewall (grey rubber in back):
Cut a hole in the rubber, ran the power wire down the driver's side complete w/ TechFlex. Installed in-line fuse holder on top of factory fuse holder. Added a Stinger negative battery terminal and connected factory grounds plus my 0-gauge to that.:
Been swamped this week, but received my rolls of RAAMmat from Rick. That is one stand up guy, recommend highly!
So this week I need to finish complete sound deadening, but I'm also getting everything else ready.
Here is where I'm at on the amps. I have this MRV-T420 that puts out 110x2 @ 4ohms. That is appx 55w@8ohms, so seems perfect for the L1s.
The JL 300/4 is 75wx4 @ 4ohms for $389.00. I can get a ED Nine.4 that is 65wx4 @4ohm for $245.00. I could use this to power both the L1 and L6, but 65w to the L6 is low since it states 150w on HAT website.
However, if I use this to only drive the L6 I can bridge and get 150w and save $140.00 over the JL.
Thoughts?
I'm not a big fan of bridging the JL slash series amps, because it doesn't make any more power. I've also seen them have issues when run that way, so I try to avoid it. I used my 300/4 to run my mid/tweet combo actively, my 300/2 for my 8" midbasses and a 500/1 for my subs. The new revamp will probably be 300/4 and 500/1
Jay
Excellent attention to detail. I am gonna keep my eyes on this one. For someone who "doesn't know what they are doing" you are doing awesome.
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
Thanks guys for the kind words. I'll have an update later this evening of the deadening finally done. What a pain. 25+ hours just to get the car deadened //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Also decided on a final power strategy:
Hybrid Audio L1 tweeters powered by Alpine MRV-T420 (110 per channel)
Hybrid Audio L6 midbass powered by Elemental Designs Nine.4 (bridged 150 per channel)
Elemental Designs 13aV2 sub powered by Elemental Designs Nine.1 (bridged 1200w x 1)
Appx 1500w overall so it should be good!
Hope to get L6 speakers rings made and midbass speakers mounted this weekend along w/ starting the amp rack.
Stay tuned.
ericnord
ericnord
Austin, Texas
ericnord
