enclosure vs enclosure help
I just built an enclosure for my two 12" hdc4's with a 10" port all facing inside the cabin of my 96 honda accord. I didn't like it at all. I lost a lot of output compared to my older box. The phasing is also weird.
Which would be a better enclosure and have more output?
36.5 x 17.5 x 22 = 6.64 cu ft gross (this box is so big that it needs to be built in two parts)
Itll have a 10 diameter port with a total of a 16" flare tuned to around 37 hz (port on the passenger side of box)
33 x 17 x 22 = 5.79 cu ft gross
Itll have four 4" flared aero tuned to around 37 hz (port on the passenger side of box)
Which enclosure would be a better choice? thanks
What are your goals?
Well, I wanna pass 149dbs which I was getting with my old enclosure. It was 33 x 17 x 22 with four 4" non-flared PVC ports tuned to around 35hz. Net volume was about 4.45 cu ft. I wanna get more output than that box. So I wanna be at it over 150 dbs for daily with a tuning of around 37hz
port+sub on same wall=cancellation. All the recommendations i see say sub forward and port up for optimal sound.should clarify also if there isnt any room between port and rear baffle or some other obstruction i have also seen port to drivers side recommended.
are you retarded?
Op try 4.3 cubes net @ 35 hz with about 65sq inches of SLOT port with 3 common walls on the driver side.
Have you tried subs up port back? That "CRX" style box may perform well for you.
I prefer a single large port over multiple small ones. If your goal is to gain on the meter, just get a meter and start playing with seat positions, small changes in box position, glove box open or closed, position of visors, flip floormats upside down, armor-all dash, flush mount subs, duct tape around subs. You can probably find .5 to 1.0 db on the meter with some testing and tweaking stupid little things like that.
Are both of the new boxes going to be subs and port both forward? Have you tried subs forward port to the side?
Do you have everything sealed off when facing forward?
I don't think it'll work with the port on the back. I wouldn't have room as this is a trunk car. Ill do the taping part. Lol thanks
You recommend that over the two choices I listed?
do you need them to be aero ports?
and im sure you will over power the hell out of them if you are doing a 49-50. 4.3 net after bracing and port should be good for them. //content.invisioncic.com/y282845/emoticons/imo.gif.3a57bcc70a4835dc53e86ffae1a0b041.gif
and if 65 sq inches of port aint enough for ya you can go bigger. i just dont trust aq's suspension with alot of port.
I used BASS Box Pro. It’s what parts express uses on most all their woofer spec recommends. I didn’t build the box phisically that is. I also...
Just remember when you pick a tuning frequency as you go higher the box gains efficiency, but loses low end and tends to become peaky.
Here’s another idea I was thinking of. I’m doing a single 12 in the center of the box just for aesthetics I was wanting ports on the sides of the...
  • Poll
I have those specs but the actual order layout is sketchy if u go out of spec a lil ur toast
It depends on how cheap you wanna go but I've had excellent results with a 12inch power acoustic gothic sub in a small sealed enclosure for budget...
72
8K
myjaja
Audioque
myjaja
San Antonio, Tx Posts: 143,632 _____<^>*_*&l
snyderd758
    May 12, 2024
Brendon Jenness
    May 11, 2024
