DSP install help
LMJexploder
CarAudio.com Recruit
I'm installing a audio control DM-810 what is the best way to connect it with the head unit? I have a Kenwood DNX-997xr . Should I use the Front and rear and sub rca outs from the head unit or speaker level inputs I have heard both ways but not sure. Looking for the best way to do it. Also I have the epicenter from audio control do I put that before or after the dsp ? Or will the dsp do the work of the epicenter and I won't need that? And then from the dsp I just run 1 set of rcas to the sub amp and 2 sets to my 4 channel amp correct. Any help or advice would be greatly appreciated. Thanks
Theres a lot to do with a dsp. You got a huge learning curve ahead of you dude.
Get rid of the epicenter, too many things in the signal line will cause major distortion and clipping, you ll blow your ****. Do the RCA route.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
716
473
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
440
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
LMJexploder
LMJexploder
Seattle WA
Jeffdachef
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
