DSP Car Audio...8-10's DD RedLine500, DD M2b, Tahoe.
  • 2
Canaan
Beatin' the block down
This is a build for a return customer. We installed the DD M2b awhile back in this vehicle with
2 Fi Q-15's in a custom slot-vent box I built, but he wanted to be LOUDER.
So, with just a slightly larger box...a few 6" flares...DD logo embossing...black carpet...
8 DD RedLine 500 10's...roughly 50%+ cone area increase (as well as motor force increase)...
LOUDER HAPPENED.
Bracing.
More bracing...plenty of time on the router.
Jay smoothing out the DD-Logo under the carpet.
His tool of choice, my Ridgid router wrench!!!
All 8 DD RedLine 510 D2's pre-wired up...ready for the box.
Cody's (the owner) M2b will be wired to 1/2ohm daily. He has been running his M2b at 1/2ohm for about a year now on his old Fi Q-15's.
Jay making the final connections to the amp.
Also, nickel plated screws on the ports for a little eye candy.
I would imagine! Got any videos of this in action? Phenomenal build quality there man.
Cody (the owner) is a regular here at the shop.
I don't have any vids now, but I'm sure I will soon.
Oh...and here is an up-coming build.
16oz Redbull.
That port is for a 4-12 DD RedLine 600 box in an 88 Crown Vic.
Wow, kinda baffled here. Once you get the tune right. You don’t need to mess with it. However, A bad tune you will. You may have different type...
16
818
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
633
Easy fix, If your DSP has a single mono output, split it with a Y and run both to the sub. In my experience, even though the sub amp has two...
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Canaan
Canaan
Monroe, Louisiana
Canaan
maylar
    Jun 2, 2024
    Jun 1, 2024
