Doing a sealed blow through with port in trunk...
  • 5
adas
Pro Seller
MurderMat
1,718
SRQ-FL
I have a question....
because I'm building a new box for my sub tomarrow, an I want to have it blow through the middle seat hole and seal it from the trunk, but its going to be a ported box with the port on the side.
I'm wondering, sealing the woofers front waves into the cabin, and then having the port fire into the trunk....how would that sound?
Here's an illustration...
I know some will say "try it" but trying it would need a different front on the box. And I would run the port in the blowthrough, but theres not enough room:crap:
Better to just face it to the back like usual?//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Couldn't find anything like this in searching, thanks:)
Technically you'll lose some of the output from the port since it'll have to fight through the seats.
For a daily driver I don't think it should be an issue though. All out SPL car then you want ever dB you can get.
And what about an external aero firing through the rear deck?
Why not try building a 4th order(bandpass with 1 sealed chamber playing into 1 ported chamber)? The sub is sealed inside teh box and that way all of the output comes from the port which you can make to match the size of the rear middle seat hole.
//content.invisioncic.com/y282845/emoticons/ohsnap.gif.17c4c91be09a7a4a3995fb7145adac39.gif
Always to the rescue Shiznilti, thanks //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif 4th order are pretty peaky though, are they not? That would be awesome but I didn't think of it since I want output from mid 30's to 70hz that bandpass would work too well. If my assumption is wrong, I'm down:fro:
And abot the aero, for the XXX the port needs to be big...I can't fit 2 4" nor 1 6" in the space.//content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
Your first drawing would make your sub act like it was in a large sealed enclosure if it was truly sealed from the trunk.
Bandpass enclosures can be peaky and they can be very flat -- just like ported and sealed boxes. If you want an extended bandwidth and flat response from a bandpass enclosure, you are limiting the efficiency and making it not as loud though.
It would be sealed off.....
So I guess I'll need a bandpass box? Anyone wantto make a desin to be like SQL more 75/25% split spl. max dems: 30w x16h x17d
I'll pay $10 paypal if I get a nice one:naughty:
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
I dont think this forum is letting that link work. It keeps changing it to a link to this forum. Try this. Just change the dot...
10
No problem. The Dayton ultimax is one of the better sounding sealed subs I’ve heard. I kinda want to try the 18 in my ride.
adas
Pro Seller
MurderMat
adas
SRQ-FL
adas
    May 24, 2024
    May 23, 2024
