different Voltage in the same setup. WHY ?
i don't think its the Isolator; Cuz the main batt is reading 12.8v which is near to ALT .. but the 2nd is 13.6v
maybe because i charged the 2nd batt. but did n't charge the main one.
Tried to charge it by the cars electrical . but nothing happend.
how do u suggest to charge it.
if i kept the car on for 2 hours. it will not charge the batt.??
lol too much trouble just fuse an call it a day.
only time i recommend a isolator is when you are like my little brother. he plays his stereo about half volume for long periods with the truck turned off. out in the woods at bonfires and ish. the isolator keeps his starter battery from going dead while hes playing it with the truck not running.
This. Otherwise no need for an isolator.
As long as you don't overpower them, there is no danger of harming your gear, once you get a new sub so they are both the same, you will likely...
Almost all brands operate the same way. Alpine, Pioneer, Kenwood. The technology is based on what sounds it can produce. Basically all brands...
THIS IS THE SAME AS THIS: One coil + to the other coil - (on each). The other + & - to the terminal block. Terminal blocks wired straight...
Hello back, For those who are also looking for a problem of sh*t bass, after such a long time of fighting, I come to a conclusion that the...
17
4K
MeMo2
MeMo2
USA . Saudi Arabia . Palestine
theMessenjah44
audiobaun
    May 19, 2024
    May 19, 2024
