Decided on a SUB but need help on the AMP !
Nyk20Z3
7
NY
I decided on this L7 12'' preloaded by Kicker its already matched to specs and looks great and should provide everything i am looking for.
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=19299
I see the RMS is 750 watts and the Peak is 1500 watts would this amp be enough to give it all the juice it needs or do i need a 1,500 mono amp to see its full potential i don't want to risk blowing anything -
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18435
Thanks in advance.
That amp is fine. If your sub is dual 4 ohms, wire it to 2 ohms and that will be fine.
Its rated at 2 ohms so i guess i need a amp that puts out around 750 at 2 ohms which would prob be cheaper that MTX i posted puts out 700 at 4 ohms buts its a 2 ohm sub hmmmm i guess i should keep looking.
Nyk20Z3
Nyk20Z3
NY
Nyk20Z3
