DC level 5 18, Powerbass XTA5000.1 in small trunk car BUILD!
Nice build man, how does your amp rack stay in place back there? Screwed into the car?
not secured yet. probly will screw it to the box and the box will be bolted to the floor
heres the rest of the box. its BUILT. Now all i need to do is goop the seems. resin it with about a gallon of resin. and sand everything down, put the ohm load changing terminals on the box, then put the sub in and ill be good!
what u have there is a horn lol ... smalller port area on the port entrance and larger on the exit
and whats up with no bracing.. u have a very large sub with prolly over 6k of power ..thats a whole lot of stress on box
Box looks awesome man, nice job on hose slanted cuts.
thanks man!
yea i know i have a horn. and all thread is what im using for bracing. 4 on the front baffle in the corners. theres no room for it o go top to bottom or side to side. good looking out though.
More progress today,. picked up half inch allthread and tightened it down the closest i could get to the middle without interfearing with the sub mounting //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif. also resined the box and threw a little test paint to see what it would look like.
GOOPING the inside of the box seams and corners.
couple pics of the dog. black lab. 1 year old. very obediant and a good helper
back to work. resin! yummy
Holes driled for the all thread
allthread in and secured down
Let me know if you ever decide to leak some of that supply. I'd be more than happy to take some off your hands.
Factory. 2021 Chevy Silverado custom trailboss
820
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
838
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
717
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
basscort2009
Banned
basscort2009
dallas tx
basscort2009
