Cutting A-Pillars for Tweeters
danpenksa
I'm going to give it a go and cut my A-Pillars to place my Hybrid Audio L1 tweeters...Any advice on cutting? How about holding the tweets in place? Guerilla Glue (they are flat-backed)?
Also, any adivce on how to make sure they are placed identically even in both pillars?
THANKS!
dp
I have found the best method of cutting for me is a dremel at medium speed so the plastic doesnt heat up and reatach after cutting. Go slow for a nice clean cut. I cant comment on glues as all the tweeters I have ever installed came with mounting hardware. Make sure you cut first on the inside of the line you draw, then test fit and cut, test fit and cut until you get a nice snug fit. Good luck.
Thomas
well its gonna be pretty fkn loud //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
hell one set of 90db tweets with around 100 watts is usually enough for me, esp with them that high in the dash
i see you got the subs to back it up... what you running for mids?
For me.. a compact amp that wouldnt take up a whole lot of room and not real expensive for a 350-600 rms sub@2ohms or even 1 ohm load id look at...
19
Restarting the phone every 1-2 days is a plus too. My moms phone is useless by the third day of not restarting. As soon as it's restarted it's fine.
932
gain set well below "Normal" and base boost is off completely
15
Yeah, it's what I thought it was, but I wanted to make sure it was actually that. I'll get to fixing it when I have the time soon. Thank you guys
danpenksa
danpenksa
Las Vegas
blackbonnie
    May 18, 2024
    May 16, 2024
