Crossover Question
kcollazo86
Hello I have a question i wanted to get a better sound for my Highs and Mids and wanted to know what Crossovers or maybe even bass blockers i can use to better my sounds my voice setup is
2 10" Ev DL10X the impedance is 8 ohms 100-2000 hz
2 6.5" beymas 6mi90 the impedance is 8 ohms and the freq 150hz- 8.0khz
i dont remeber what kind of tweeters but there 4" dome titanium bullet tweeters there 8 ohms
The amp i have runing to this is a SoundStream TRX 4.880
hopefully somone can lead me in the right direction //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Yeah I knew I had a crossovers on the amp. Just thought I could clear my voice alittle more... is there anything I can do to get a better and maybe little more louder voice out of my speakers each speaker is ran to there own channel... but they had told me to run everything and bridge it and run it al to one channel and just get bass blockers for the speakers but tha sounds alittle nuts to me...
yes if im not mistaking i can mess with the slope... but what if i get a Equalizer would that help me on my system more to get a better sounds or its not worth it ? would like to get the opinion on somone before i jump into something thanks guys //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
So you're powering each speaker independently on its own channel, resulting in the full range of frequencies being produced by each speaker...correct?
If so you'll need a HU, amp or external processor w/ active crossover capabilities to filter out the frequencies the drivers don't like. I would'nt recommend it to a novice w/o a good understanding of crossovers/slopes & phase relationships.
Or you can get a passive crossover & take an educated guess @ what x/o points will work best. It would kinda be a shot in the dark, but then you could bridge the amp & send each channel to the passive x/o which will then split the frequencies between the front speakers accordingly.
I think your best bet would be to sell the fronts & pickup a new set of components. Bridge the amp & use the passive crossover that is supplied/designed for the comps.
can you adjust the slope on it from 0 to 180? Would that help
No. I think you're referring to phase
So you're powering each speaker independently on its own channel, resulting in the full range of frequencies being produced by each speaker...correct? If so you'll need a HU, amp or external processor w/ active crossover capabilities to filter out the frequencies the drivers don't like. I would'nt recommend it to a novice w/o a good understanding of crossovers/slopes & phase relationships.
Thanks this helps alot .. Do you guys think getting a eq will do me any good if so which. One is a good one ? ThAnks
kcollazo86
kcollazo86
Jersey
kcollazo86
