Crossover and pre-outs
Gookie
Just installing my first system... And, something just came to mind...
(Got a JL 500/1, with a JL 10w3v3, and an Alpine 9885)
Anyway, the high pass crossover setting. What does that do exactly? And what I mean by that is, my amp is hooked up to the pre-outs. Do the pre outs get full range all the time, or are they affected by the crossover??
It would make sense to me for the pre-outs to be full range all the time, in which case I can do exactly what I want and set up the crossover/parametric on my amp, yet have none of the lower frequencies getting to my component speakers. If the pre-outs are affected by the crossover, then, what's up with that, and how does this work?
First system. I'm a car audio virgin. Please be gentle.
HP sends all the freqs above whatever it's set at. You should be able to turn it off or bypass it in the HU. But personally I'd set the amp to FULL and do the xover in the HU since it's a digital readout and easier to set, unless your amp has better slopes...
maybe I wasn't totally clear.
Say I set the HPF on the deck to 80Hz.
Are the frequencies going to the pre-outs and the rest of the speakers the same? Or do the pre outs get everything below 80Hz and the speakers everything above? Or is everything below 80Hz drastically reduced, both on the speakers, and the pre-outs??
I'm basically adding a deck, a sub, and an amp to my factory speakers. I want high frequencies to go to the speakers, and everything below say 80Hz to hit the sub. Can I accomplish this with the equipment I have?
Gookie
Gookie
Canada
hemi=22s
