crossover and eq confusion help please
BadmonBuilt
i have a p4000dvd double din with 2 pre outs and want to go active and also use my 9 band eq
i have a KEC-202 crossover and KGC-6042A 9 band eq
would i be able to use them both?
incase you need to know i am running three 2 channel amps one for tweeters one for mids and one for sub
ID nx30 tweeter powered by rf 150a2
ID cx62 Mid powered by rf 360a2
Pioneer 2000spl powered by rf 1100a2\
if any other info is needed let me know thank you in advance
i may be wrong but i think you need front pre outs rear pre outs and a sub pre out to go active, i dont think it you can with just 2 sets of pre outs.
i can as the eq only uses one input and splits the signal the problem is going from the eq to the crossover and the crossover only has one input
do i have to run the 3 outputs on the equalizer i am using together into one on the crossover
HU to eq to xover input then the xover has 3 outputs sub, mid and highs, sub output to sub amp input, mid output to mid amp input, high output to high amp input.
BadmonBuilt
BadmonBuilt
florida
JeepBeats96JGC
