Crossover and amp
I have the Kicker 03KX3 3-Way Active Crossover:
-3-way 18dB/octave active electronic crossover with one variable low pass and two variable high pass filters
-High-pass crossover frequencies from 35 Hz - 400 Hz; low-pass from 45 Hz - 250 Hz
-Remote control bass boost is variable to +18dB at 40Hz
-24dB/octave subsonic filter, two stereo inputs, and three stereo outputs for versatile control
Nice cross, but you may have to use the cross on the amp/s to filter the signal accordingly. The KX3 has a good line-drive so discipline yourself with the amp's gain.
Kicker ZX750.1 750-Watt Class D Mono:
Max power output 750 watts x 1
RMS power handling 4 ohms 375 watts x 1 2 ohms 750 watts x 1
PEAK Power Handling: 2 Ohms: 1500 Watts x 1 Channel
Frequency response: 20Hz-20000Hz
Tuned bass EQ (0-18dB bass boost at 40Hz)
Variable high-pass filter (50Hz-200Hz 12dB octave)
Variable low-pass filter (50Hz-200Hz 12dB octave)
Subsonic filter (24dB at 25Hz)
Pushing a KICKER Solo-Baric L7 S12L7
KICKER ZX850.4 Class AB:
Max power output: 850 watts x 4
RMS power handling 4 ohms 175 watts x 4 2 ohms 215 watts x 4 bridged 4 ohms 425 watts x 2
Pushing 4 O2 6.5 8ohm speakers, two in the front in parallel and two in the back in parallel as well as 4 tweeters.
I've put my amps on full except for the bass boost as you suggested and tweaked the EQ on my Pioneer DEH-6000UB HU a little bit to tune it and it sounds good. But your saying to be conservative on the amps? Should I pull back some on the the amps gains? I don't want to risk getting them hot, will they be more prone to this...thanks for all your help.
flava30
flava30
NYC
ginxdor
