- Thread Starter
- #16
why shouldnt i get a 2 ohm driver and then wire it at 1 ohm to get the full 1200w then?Not with a single DVC 4 ohm subwoofer - you would need a DVC 2 ohm driver.
even if i wanted to go 1000w i could set the gains down.
The sub is what determines what load the amp sees.is it not possible to wire the amp for 1 ohm and give the sub the full 1200w?
The voice coil configuration and the way the sub is wired determines the ohm load the amp sees which is what determines how much power the amp produces.what? i thought u could send whatever wattage you wanted through a sub..?
