Chris isnt loud, hes quiet af
Chris McNeeley
Red Light Ear Rapist
finishing things up on the rebuild, figured id post pics as i go, 145 here i come!!!
removed dash and gutted all ac with sawzall, welding steel plates and poles all over the firewall as its my only weak point
total wall thickness all around is 4.5". sides before and after paint
my **** alt setup, yeah its ok to be jelly
my custom lithium titanate battery with my diy buss bars
more to come, to hot out to take more pics, rushing to be done for slam
Did u do a 2x4 frame for the enclosure? I was think of doing that for my 2011 Tahoe build.
yeah but it was tricky as f*ck, angles took forever and each side is fully against the frame and bonded with 8x, its built to the car like a roll cage using every square inch i could get, had over 35 cubes to play with lol
Gramps I built all this in my garage with a drill press and angle grinder, you can do it to don't be a p*ssy
no i realllllyyyyy can't!!! also can't afford them, all i need is 1 270 and a 2nd batt but those would cost more than my entire set up lol..
Try going into your settings and look for system sounds. You may be able to adjust it there. Or, you can go into your phone settings, look for...
LMAO.yep,this setup going on over 9 years.appreciate the inspirational quote although i dont take part in water boy memes.
10
859
Welcome to the forum. I hope things go well for you. We like good products made in the USA. I'm cool with paying more to get that.
No rc bug yet? I got bit bad and left audio for years doin rc again.
22
4K
Did you try the red on both sides, then the white on both sides. It may be a bad cable.
Chris McNeeley
Chris McNeeley
Toledo, ohio
Chris McNeeley
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
