Charging problem..
JEXTEL
Well i have bought a Iraggi Alternator (220amp) about 2 weeks ago installed it everything worked fine until today i was listening to music and notice a burning smell(not amps or subs) like tires burning so I cut everythng off and pulled over after looking at my car and everything i notice my volts were only at 12v then i rev the engine alittle and it went to 12.2v before it would be about 14.2 then idle around 13.6-13.7..I was going to upgrade the wires some more today once i got paid because my big 3 is done in 4 gauge and my wires going to the second battery is 1/0 gauge. I was going to add 1/0 to the big there and do another run of 1/0 until i can get some more money..I check all the grounds and amps and everything seems fine but for some reason my volts are at 12v only..what happened? I didnt blow and fuses i check them too..
Could it be the battery in the trunk? im going to exchange it torrommow..(its like the POS. side where the bolt is WELDED it self to the thread) Cheap *** walmart battery...//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
i've burned up a few batteries with the snow plow. it smells similar to rotten eggs when they burn up.
ill find out torrommow when i swap out the batteries
Maybe something went wrong with your alternator..? I don't know, that was just the first thing that came to mind.
me too..i just hope not //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
Ok everyone i took out the alternator today and notice that a part inbetween the case where its solder to another part has been broken.(im hoping that the only problem) I emailed Dom and prolly will call torrommow I also notice some solder resin on the case like alittle sloppy job. I know when i bought the alternator he was busy getting tons of alternators ready for SBN.. i just hope he didnt rushed the job..
JEXTEL
JEXTEL
Bridgeton, NJ
JEXTEL
