Amp Trouble
the problem is that my amp will power itself off when i connect my four 12s and turn up the volume, because of that i usually run just two 12s.
The Subs: the visoniks are 12"single voice coil 4ohms, the pioneers are 12"single voice coil 4 ohms
The Amp:
Lanzar vibe 268
2 x 500 Watts RMS at 4 Ohms
2 x 1000 Watts Max at 4 Ohms
1 x 2000 Watts Max at 4 Ohms Bridged
2 x 800 Watts at 2 Ohms RMS
Electronic Crossover Network
Bass Boost Circuit
Bridgeable at 4 Ohms
2 Ohms Stereo Stable
Gold RCA Inputs
Line Outs For Left & Right Channels.
Power & Protection LED Indicators
Advanced Protection Circuitry
Soft Turn On/Off
Remote Control Bass Booster
Frequency Response: 15 Hz - 35 kHz
S/N ratio: 90dB
Dimensions: 11.5''W x 2.3''H x 19''L
Any additional info you might need feel free to ask
why.... why 2 sets of diffrent subs.....//content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
anyways what kinda of subs are they DVC SVC?? what ohm are they.
i know i shouldnt have but the second set were free and i got bored one day
It's because you can't run two different brands of subs on the same amp... //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
Sorry... I couldn't help myself. It's shutting itself off because when you wire 4 SVC 4 ohm subs in parallel, you get a 1 ohm load, at which that amp is not stable. In essence, by shutting itself off, it is telling you to stop being retarded. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif The only way your setup would work is if you wire two subs in parallel on each channel. Don't bridge the amp.
thanks
//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif x2 youre amp doesnt like 4 woofers especially theyre not the same..//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
412"suB_urban
412"suB_urban
Pittsburgh
patotay
