CCA amp kit help
Any good boxes you'd recommend I have about 250 to spend on a box
i was gonna tell u about northeastbassfactory made great boxes but just saw they closed for good old guy is sick... u can probably get custom one made for $300 maybe., cscstang here could do it but he's very busy idk about shiiping between ya'll and all that either but he can build a box..
Yes tune to 35... but go with 45-50 in2 port area to run that amp at 1 ohm in a 2.5 ft3 net box.
Those subs really look nice in a 2.5 ft3 net with 50 in2 port area tuned to around 32 hz... that's about 30" long... those prefabs will do all right but might have port noise and lose output due to port compression... Are you planning to run the amp at 1 ohm?
Any particular reason that you are looking to buy online?.. It looks like you are in CA and there are lots of options locally I'm sure... for $250 you should be able to get one built for YOUR vehicle and let you run that CAB amp as it is meant to be!.. I'm not a salesman but I would like to see you get the full use of your subs potential... I love those cab amps!... https://www.youtube.com/watch?v=GsCV_SyyyJQ ... build your own box if you can!
Yeah there are a lot of places here but most only sell prefabs the ones that build want 350-500 for a box
Man that suks!.. IDK about your area but here in PHX you can find some pretty talented builders on Craigslist... Maybe making side money?.. Really IDK... Those specs I gave will work well...
Can you lay out the specs for box for the 2 sa10s again I may have found someone willing to do it for 220 locally
This ^^^
SRT8 Wolf
SRT8 Wolf
CALI
shredder1
vegang
vegang
