CCA amp kit help
SRT8 Wolf
CALI
So I just got a CAB1600.1D amp for my 2 Sa10s and I have a 160amp alt I'm looking to upgrade my wire from 4g to 1/0g Im wanting to know if I can just go with CCA wire or will it cause me problems. The amp kit I'm looking at is on amazon it's by KnuKonceptz it's $37.88 my budget is 50 bucks
I would use your entire $50 budget and get better wire. If you pay once it only hurts once //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Look on ebay you can buy wire by the foot or find a kit that may be slightly over your budget but probably worth the few extra $ You can get 20' of copper for $60 shipped
Stick with OFC. Do it right 1st time. I've bought many times from Knu.
Btw, how's your electrical besides a new alt? Big 3 done? Same stock battery or newer/better one?
Not very good to be honest, big 3 not done yet and I have a xs power d1200 as my second battery but have yet to install it I'm waiting on my wire I just said screw it and dipped into my saving and got the stinger amp kit the Sk6201 kit to be exact my alt is stock and I still have my stock battery it's just hard to find a alt for my car it's a 2011 Dodge Charger the only Alts I see are 400 bucks any help on where to find a good alt
There is nothing wrong with cca wire to a point. If your trying to pull 300 amps then definitely need ofc. If your only pulling 200 amps then cca is a fine choice. Ofc would be better and would be better for the big three due to less resistance. Personally im a fan of cca for light use
Cca will corrode and will be junk and you will have to buy new wire... CCA is junk. Buy welding wire
Yeah I'm only gonna be running a CAB1600.1 and I'm looking to get the xs power big 3 kit. do you think I'll need a new alt or is my stock 160amp good enough?
Stock 160A?... heck yeah you're good unless you compete... I wish MINE came with a stock 160!
yeah mines 125 and peeps tell me i'm lucky, guy said his truck had 95a..
432
It mostly comes down to weight. You can have a super lightweight cone, soft suspension and aluminum coil on a sub and you pretty much get a pro...
896
fwiw... https://www.pasmag.com/technology/dash-kits-accessories/oxygen-free-copper-ofc-vs-copper-clad-aluminum-cca-cables
I’m at 3 yrs on my Tucson alternator. W the electrical challenges i faced it’s been worked hard. Thankfully those challenges have been overcome...
99
9K
At 100 watts and such short runs, you’d have no perceivable difference between 12, 14, or 16 gauge speaker wire, OFC or CCA, nor worry about...
10
SRT8 Wolf
SRT8 Wolf
CALI
shredder1
    May 20, 2024
    May 20, 2024
