Capacitors wires question
  • 4
Russ130
I going to install a 3000 watt peak power system in my car. I want to add a capacitor in it as well. What gauge wire should I use? I know if I was not running a capacitor I should used 0 gauge. Should I still use 0 gauge or can I use smaller gauge?
Capacitors are usless unless you're using banks that have ~200f+. Sounds like you're using one of those cheap 1-3f caps. Useless, don't use it.
I doubt you're actually putting "3000w peak" in if you're talking about a cheap capacitor. Ditch the cap and just get 4 gauge ofc. That's all you need.
Quit looking at peak power. My guess is your gonna run 1/2 that which most of the time is RMS power, root mean squared, continuous power.
And ditch the cap. It's just a band aid cheap route to beef up your electrical. You want to at least do the big 3. Plenty of YouTube vids/know how.
If I was in your situation, I would experiment with the wring for a day or two. If that didn't work, I would purchase an external amplifier. Run...
978
I didn't read the article, but with those GM Bose systems; either fix what needs fixing, or rip out the entire thing and start from scratch with...
Try placing the subs in the front seat, to see if the issue persists. Just for diagnostic purposes. It may be wiring, but the distortion may be...
947
Russ130
Russ130
California
Boomin_tahoe
slater
    May 2, 2024
slater
    May 2, 2024
