capacitor volts dropped
zergclaw
well ive had this system in my truck for close to a year nothing has changed.......the only thing that has changed is that recently it stopped working no sound full power from battery to cap to amp to subs.......but no sound so i opened up the dash and cut the amp power wire then for shits and giggles i recrimped it....and low and behold it works perfectly now ......the other thing i did switch is i went from front preouts to sub......and works fine......this is where im lost i have maxed out any setting having to do with base and still can not get my subs hitting as hard as they did when they were on the fronts......one key sign i see is that when my subs hit the cap volts use to really drop...now it drops like .1or.2 max also the starting volts dropped from 14.2-14.4 down to 13.7-13.6 this is the volt at idle from the capacitor readout....any1 have any idea what would cause a volt loss since it probably is effecting the loudness of my subs???
because it really does more harm then good. You also need to learn how to properly set up your amp and head unit. You DO NOT max out the gain, bass boost, bass whatever. You will kill your subs
im not a complete amatuer ****..........i never maxed out the gain .............i did turn it up temporarily.........same with bass boost as well
What would make you decide to just cut your power wire? and then recrimp it, and what do you mean by recrimping it? Did you just put a new eyelid on the end and to your battery?
why would i do that
There is not a single positive that comes from running a capacitor. However, there are a few drawbacks. They will actually harm your vehicle's electrical. There is a great write-up on them, give me a few minutes to find it.
But what about the hot Spanishasianrican "fast & furious" chicks that the caps may draw in? May hurt his street rep!!!
I run Caps on all my mid amps //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif....
course most people don't run 1000 rms to mids lolz
Then you don't know what the hell you're doing, no offense. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
all a matter of your uneducated opinion on it //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif ( no offense )
they have there place if used properly... for subs they are worthless...
I have read hundreds of writeups by EE's ect... every amp made has caps //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif....
when you compete in SQ you will understand //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
and I use S.S. hybrids not the ghey foil types..
that drop is nothing. i can lick my fingers and grab ground and hot and make it drop.2 .. capacitors are trash. You sure you didnt lose a coil or something and thier only playing half way.. and im lost with the pre outs changing them to sub. You dont run your sub amp off anything but sub preouts...
like i have said 1k times. bob has no real life experience. all he knows is what he has come across on the computer.. thats why hes looking for a write up right now.
not the same //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
educate yourself.........
After studying a little history on large 1 Farad capacitors in car audio, you'd be amazed that they even sell at all. How useful are they? What do they really do? Will a Cap 'improve' my sound quality? Will it Prevent my lights from dimming? Will it audibly affect my audio system in any way?
Before you get the truth to any of the above questions, chances are, you've probably spent $100 or more on one of these devices. However, let's study a little history regarding this issue.
A long time ago, in a land far away, 2 elves...Ok, Richard Clark & Wayne Harris (Carsound magazine and the inventor of DB Drag, respectively) separately came up with a solution to preventing their lights from dimming.
WHO WERE THESE GUYZ?
As you may know, Richard Clark is one of the founders of autosound2000 Tech Briefs, Carsound magazine, and a published author of the industry of mobile electronics. In SQ competitions, he posted a record of 1234 1st place finishes, and only ended up NOT 1st in his first event. I've heard that he had minor system problems, but judging by his record, he must have corrected it. (evidently, he needed a capacitor )
Wayne Harris was previously a leader at rockford fosgate in their development. Later, in his free time, he created the organization we call DB DRAG. Wayne was the first SQ World Champion from the organization we know as IASCA (International AutoSound Challenge Association).
Both of these gurus are both legends, and considered the leading experts in the field. During their competition days, both guyz came up with a way to assist in the prevention of voltage drops. In SQ competitions, the look of your system is actually more important than the sound, and having your lights NOT dim under high playing levels is a competitive advantage.
As you may know, amplifiers are made up a bank of little capacitors, resistors, etc. What has been common engineering knowledge is that capacitors store energy, and more or bigger ones assist in balancing the power supply.
Wayne came up with the idea of putting several dozen 'little' (approx 100uF) capacitors on a circuit board to 'extend' the power supplies storage. At about the same time, or shortly afterward, Richard came up with the idea of one huge mondo capacitor (I believe it was 800,000uF or 0.8F) to do the job.
Eventually, Richard won. The large cylindrical tubes won over the complicated 48 caps strapped to a circuit board. However, what did this really accomplish? Let's start here:
WHAT IS A CAPACITOR?
Basically, capacitors are an energy storage device. Large, 1 Farad or more
capacitors store energy (electrons) between their plates. Capacitors differ
from batteries because batteries store energy in the form of chemical
energy--and rely on acid and lead plates, as the place of storage. For a more detailed
description of a capacitor, go here:
http://www.eatel.net/~amptech/elecdisc/caraudio.htm
Then on the right hand side, scroll down to CAPACITOR. Keep in mind the use
of capacitors in an audio system.
WHY DO PEOPLE BUY CAPACITORS?
The number 1 reason would have to be because their lights dim when their
system is playing HARD. In car audio, we are told that a capacitor is
designed to prevent the voltage drop associated with your lights dimming.
The number2 reason is that it is rumored to 'improve' sound quality or
'stiffen' the power supply/source.
WHY DO MY LIGHTS DIM?
Headlights brightness is in direct proportion to the source voltage. For
instance, if your car is running, system voltage is ~12.5 -14.4 VOLTS. Your
lights will be much brighter than when your car is turned off--where battery
voltage is ~12V. Most car alternators put out between 75 to 120 amps of
current. When this current draw threshold of the charging system is
exceeded, system voltage will drop as power demands are now shared by the
alternator and the storage devices (battery & cap). We are using battery
reserves beyond this point until the demand lessens
When playing your system really hard. Your lights dim because your
alternator can't keep up it's charging voltage (around 13.5V) and therefore,
demand exceeds output. When this happens, your electronic devices are
dipping into the power storage of the battery. Since the battery stores
power at ~ 12-12.5V, there is a 1.3 to 1.8V drop in voltage available. This
in turn is why your lights dim down.
HOW MUCH POWER DOES A CAPACITOR STORE?
1 Farad = 100 joules or 100W/second
850cca battery = ~2,200,000 farads
For storage purposes, you'd need ~2,200 1 Farad capacitors to equal the energy of your battery.
Due to its impedence (ESR & ESL), a cap's energy is only 50% available. What's worse, is that in order for a 1 Farad cap to discharge, first the alternator output must have maxed out, and the voltage must have dropped around 1.5 volts. But I thought a cap was supposed to prevent that (voltage drop)!!!!!????? Yep, you got the point.
IF A BATTERY = 2,200 CAPS, THEN WHY BUY A (PUNY) CAP?
My question exactly. Marketing is the reason why people buy caps. In many cases, upgrading wiring will help your system get the maximum transfer of current. Once that has been reached, adding a capacitor may have a minor effect on your system. 50W over the course of a second is not a lot of power considering an amplifier may draw 2000W to put out 1400 watts. Let's look at the situation from a resources standpoint.
Alternator 80 amps
Car accessories (minus stereo) 40 amps
A large Car Audio system (DRAWS ) ~200 amps AT FULL OUTPUT
In this case, you have 240 amps of draw, but only 80 amps of current from the alternator. In your case, you need 160 amps x 12 volts or or let's say 1920 watts of energy. Since a cap stores 50W, how much of a difference do you think it's going to make? A cap is basically a peashooter. W+e need a Howitzer cannon here, to do the job well.
Also, Once a cap is discharged, where does it get it's power from? The alternator, which is already overloaded. Once a cap is discharged, it's worthless. Like SWEZ says, ・.The cap already shot its wad, an does limp til recharged・ I知 not so certain I will allow him to babysit my kids, but you get the drift. (I never said it quiet like that... and oh...I'm great with kids!)
SO, WHAT IS A CAPACITOR GOOD FOR?
1. Audio Jewelry- impress chicks with large cylindrical shiny thingy
2. Extra weight in winter time
3. A very POOR... BUT expensive distribution block
4. A projectile in the event of a crash
5. Rolling pin--for cooking purposes
6. A neat thing to tell your friend, "..Hey man, lick the top of this..
Please do not try # 6. New hairstyles are always refreshing, but if you are wearing railroad tracks across your teeth, you might have one big filling after it痴 over.
HOW CAN CAPACITORS IMPROVE SOUND QUALITY?
They can't. Sound quality is not dependant upon the presence of large bulky 1 Farad capacitors. How many 1 Farad Capacitors do you think the Boston Pops, Aerosmith, or Snoop dog use in the recording studio?
IN A NUTSHELL.......
When Richard, our fearless inventor, became World renown for winning every competition under the sun, people began copying what he did. Soon, every 'serious' competitor had a 'stiffening' capacitor--not to be confused with the 'loosening' capacitor.
WHY?
In the late 80s, people began sticking out their tongue when dunking the basketball because Michael Jordan did. Did sticking out your tongue improve your dunking ability? Same here with adding a capacitor to your electrical system.
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Going all Knu for wiring, lugs, and fuse holders. Been using them for the last serveral vehicles and love their products. Battery terminals...
zergclaw
zergclaw
Santee, CA
grandam888
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
