Can't get this to work, what am i doing wrong.
Boof150
So i was messing around with my truck today and was trying to wire up a Selenium D250-X and had it hooked up to this JL 4300 amp i had laying around. The speaker is brand new and i know the amp works because i have used it on and off again for different setups in the past. I first tried wiring the selenium up bridged between channel 1 and channel 2 to see if it would play sound and what i got was mostly static/whine and the speaker trying to play bass notes. I messed around with the filter settings on the amp and on my head unit but i was unable to get the selenium to play anything other than static/whine and very quiet vocals. Is this a crossover problem or is this amp and speaker combo not compatible?
I found these pictures from another user on these forums of the amp in question.
Playing around with the speaker i have come to the conclusion that this is a crossover issue. Setting the headunit and amp to filter at 200hz, which is the highest i can set them, i get the most sound out of the selenium. My question now is how do i go about increasing the crossover point to the speaker's correct range. Is this something i can do on the headunit and amp or do i need to set the crossover before the signal reaches the amp?
What my concern is now is that the headunit seems to have no setting to turn off it's filter, i only have the option to toggle between numbers between 50-200hz. Would getting a seperate crossover eliminate this issue or would the head unit still only send frequencies up to 200hz to the new crossover?
It will probably change your tuning. I've seen bigger numbers off of much less power from walling at the rear seats, but Terry "trunk king" Brock...
Can anyone in here participate in a short interview I am doing for school about the installation of a Kenwood DMX4070S in my 2005 Ford Expedition...
When I was delivering pizza the companies had to raise employees wages and in response they hired twice as many employees and cut everyone's...
14
59
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Boof150
Boof150
United States
Boof150
Decebal
    Jun 10, 2024
