Can you run components in bridged mode
Each side of a component set is getting a mono signal anyway //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif The left side is getting only the left channel's audio information and likewise for the right.
No problem at all with what you want to do. //content.invisioncic.com/y282845/emoticons/thumbsup.gif.3287b36ca96645a13a43aff531f37f02.gif
yes, you will have to use Y adapters to send the left sound to channels 1&2 and bridge those for the left side, and then split the right sound for channels 3&4 for the right side
or you can bi-amp them depending on what comps they are
What kind of amp ? I have several of the older "A" series rf amps that you can't . They combine the fronts - one channel rears to another channel //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
That will be entirely dependant on the amp.
Some amps can create a 4ch output with only 2ch input.
WHAT?
O.P. Read your manual and see what it says about connections and running in bridged mode. If it's a 4-ch amp and mentions running in 2-ch bridged mode, possibly just 1 rca in each side, and it's probably labeled.
dkmesa
dkmesa
Atlanta
wesl56
michigan born
    May 14, 2026
michigan born
    May 14, 2026
