best way to wire these subs
GreenGA98
Mike was here
6
OHIO
Hi everyone, i'm new to this site and just have a quick question
I have 2 Kicker CompVRs, 4ohm DVC, 400w rms each, 800w max each
Rec. Sealed Box Dims: 1 - 4.6 cu.ft.
Rec. Ported Box Dims: 1.75 - 2.25 cu.ft
Free Air Usage: not recommended
Sensitivity: 86.7 dB
Frequency Response: 25-500 Hz
Recommended RMS Power: 400W
Peak Power Handling: 800W
Impedance: dual 4 ohms subwoofer wiring options
and an amp Power Acoustik LT980
2-Channel Amp SpecificationsAmplifier Type: 2-channel
RMS Power @ 4 Ohms: 220W x 2
THD at 4-Ohm RMS Power: 0.02 %
Bridged RMS Power @ 4 Ohms: 560W x 1
Speaker Level Inputs: no
Preamp Outputs: yes
Built-In Crossovers: HP/LP
Bass Boost: 0 - 24 dB
Frequency Response: 10-30,000 Hz
Signal to Noise Ratio: 98 dB
Fuse Rating: n/a
WHat would be the best way to wire my subs, right now they are wired parallel with the amp NOT bridged. Can I bridge my 2 channel amp for more power, just wondering?
Meh I would give it more power...but if you already have the amp it wont be too bad. Wire each sub in series to reach an 8 ohm load. Then wire both subs in parallel for a final 4ohms and bridge the amp...
//content.invisioncic.com/y282845/emoticons/word.gif.64b12e39f936af3b4fff38a1c0bd0244.gif
The other option would be to wire each sub in parallel and drive each of them off of a single channel @ 2 Ohm stereo.
The option mentioned by Fast1one will give you a lower overall current draw and a cooler-running amp, however and is the better option of the two IMO.
GreenGA98
Mike was here
GreenGA98
OHIO
Prowler573
michigan born
    May 14, 2026
michigan born
    May 14, 2026
