Can I run power and ground in series?
ccajun4real
I am going to run three small amps for my system. 1 X JBL 180.2@4 ohms, 1 X JBL 150.1@ 2 ohms, and 1 X MTX 4122@ 4 ohms. Can I run the power lead and ground in series or do I need distribution blocks for this? Also can I run the remote lead in series? Thanks
Cajun
use a distro block for the power... for the grounds just run a ground for each one... the remote lead you can do like that
sexxxy car btw!!
free post lol
relay is a small switch with a magnet on the end of the switch, and an electromagnet also inside -- you can then use a 12V signal (to the small electromagent) to switch something on/off.
the idea is that the HU's remote lead is made for low current. 3 amps should be ok. but if you wanted to run fans or such from the remote line, you could use a relay. the remote line would attach to the electromagnet and switch on a higher-current 12V line for fans, ect...
other devices also work, but relays work at high currents, and are easy to use, and are self-contained.
really a moto i live by is, if you don't know what you're doing, then don't do it. not being a ass cuz i have to remind myself of this alot. also why isn't your sig in this post but is in the rest?
Well if you never try it. How do you learn?
ccajun4real
ccajun4real
Watertown, NY
ccajun4real
