Cab 2000.1
Anyone who is "smart" knows better than running a 200$ amp that low. Even then you set the gains and understand the outputs are limited to 1600 they won't burn up.
Would you stfu already. You constantly say stupid sh*t about things you know nothing about, try to back pedal, then end up contradicting yourself on a regular basis. A schmuck indeed.
people ran the cab at 1/2ohm. try that with other budget amps.
---------- Post added at 07:28 PM ---------- Previous post was at 07:27 PM ----------
U say run at half ohm and then u say it’s dumb? What.....
You can't assimilate or comperhend. I said anyone who knew better isn't buying a cab.
Also you should interpret from this statement that people have run them at ohm and they haven't failed.
Guy here matter fact has two running at .5.
You stupid.
Guy here has two at half ohm. I've seen two personally run 1/2 ohm. One guy is a rookie the other guy is a budget baller.
Stick to insults because you know Jack's **** about audio.
You could fit 2 SVC Dayton HO 10's ported behind that seat no problem.. You would need a amp that puts out power at 2 ohms.. If you had bucket...
14
Ok so I started my install . I am doing it in stages so I am not without music for a week or two . I started by building and mounting the Amp...
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
bigblank69
bigblank69
Eureka, MO
MasterJones93
