Buying front stage.
IshbOO
Im looking into buying frontstage system within the next few weeks. My speakers are blown and needa replace them asap. I'm wanting a component system 6.5 and i think the mounting depth needs to be below 3 inches. I will install a 3/4 mdf ring as well. I have an amp also.
I got somewhere around 100-200$ to spend
Anyone have any suggestions?
I have been looking at Orion P6.2 system, Anyone have any info on these? I know thye make good amps and subs, How are their comps?
Also the Crystal sscs6 but ive heard fellow integra owners have ran into problems mounting them.
I want a comp system. And I will be running off the headunit for a month or so. The amp I have will be running 100-150 rms at 4 ohms. And the orions are 3ohm VC.
I want strong midbass, and some loud tweeters. I have never heard titanium tweeters but willing to give them a shot.
The P6.2 are excellent, if you can still find them... I think they have been discontinued.
Better yet would be Cerwin Vega V-Max 65... do a search on Froogle.com
The Crystal SSCS is bigger than a standard 6.5"... I know the hole cut-out is 5.75"... I believe the mounting ring/outside diameter is bigger also... not sure of the exact measurement... probably closer to 7"
Orion HP2800 ?
Max Power 600
4 Ohm Rating 125 x 2
2 Ohm Rating 200 x 2
1 Ohm Rating -
Mono Rating 600 x 1
Freq. Resp. 20 - 20khz
THD+N
Damping factor > 200
Signal to noise ratio > 77
Crossover range/scope LP 20 - 3khz
HP 20 - 3khz
Input sensitivity 200mV - 5V
Safe load impedance 2 ohm stereo
Equalization Circuit Intelli Q
10 db
Remote level control N/A
Amplifier protection* T,D,R,S
Externally Bridgeable No
Dimensions** 12.6” x 10.2” x 2.4”
*T - Thermal protection, D - DC offset protection, R - Reverse polarity protection, S - Short circuit protection, O - Over/under voltage protection
* All power ratings are @ 13.8VDC supply Voltage, all channels driven
** Amplifier dimensions are for heat sink only; add 2 1/2 inches per side to allow for end cap installation
Good for crystals? 4 ohms right?
IshbOO
IshbOO
St.Louis, MO
IshbOO
michigan born
    May 14, 2026
michigan born
    May 14, 2026
