2 way or 3 way front to replace factory 3 way
Speaker magnet may be too wide to clear into the mounting bracket, tempted to buy and try and return if not
I had another version of those speakers once in my G6 that had 3-way factory speakers in the doors. The magnets can be problematic.
So the rx350 factory stereo has to stay in , I’m bypassing the factory pioneer amp using a pac audio module so my signal will be relatively flat and I’m using a relatively budget dsp either the zapco hb-48 blue note or the b2 audio 4-10 dsp. My other vehicles have mechless single din pioneers in them that are setup 3 way active with 13band eq’s so my ears aren’t that sophisticated. I’ll probably tune it once, set snd likely forget unless I really get a wild hair up my *** to constantly retune.
My man Idk if you've already made your decision or not. I have the B2 sixten dsp. I would not buy it again. Only having access through the app is not ideal. It makes it harder to set your eq's. and crossovers. It also sometimes doesn't correctly load settings memory, and there is no gain output control to match all your amps. If you're planning on tunning with REW this DSP is not supported making it more difficult to use than the Zapco. The zapco software is much more user friendly. Just my honest opinion as a B2 SixTen owner.
2000 Jeep TJ
Jvc KW740-BW
JL audio C2 midrange (Kick Pod)
Deaf Bonce 3" AP-T25Neo Tw
Deaf Bonce Machete 6.5" midbass
DS18 3" super Tw
Orion HCCA12-4 Sub-Woofer
JS Alternators H.O. 320 Amp Alternator
TARAMPS Smart 5K
Zapco C2K Competition 4 channel
PPI Art series A404.4 4 channel
B2 Audio SixTen DSP
KnuKoncepts Zero gauge OFC
2000 Jeep TJ
Jvc KW740-BW
DS18 3" super Tw
TARAMPS Smart 5K
B2 Audio SixTen DSP
He's looking at the Goldhorn 10-ch DSP/amp. It has both a phone and a laptop interface, an excellent DSP amp.
BCotrell
BCotrell
irvine, ca
Doxquzme
Mike Mccabe
Giles
    Jun 27, 2026
