build help.. please.
chinxtaboi
tx
built my box.. bass doesnt sound right.. not round.. and in the trunk sounds weird. almost like an echo.. sharp sound. no air leaks.. what could it be? ive never had this problem before.
help please
set up memphis mcd-500 and m3
help please
your port is too small. the port area should be around 30-35
so should i keep the dimension just make the port area bigger? put all that work into it and its messed up..
sigh..
no, making the port area bigger will reduce box volume. Just start over and do it right the 2nd time. 12-15^2 per cubic foot of box, so around 25^2 or so would work...
found the problem.. it was an air leak.. tightened one of the screws on the sub to the box.. and viola.. all fixed.
Crutchfield can tell you what speaker will fit your car. for subs, Image Dynamics and Adire are still around. my last sub i bought was from...
934
Thanks everyone for the feedback. I got scared of the 4th being to much for a newbie but did end up building a box to 2.1 Cubic Foot tuned to...
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
10
4K
chinxtaboi
chinxtaboi
tx
chinxtaboi
    May 24, 2024
    May 23, 2024
